I hear "QR code incorrect" during doorbell setup.
Problem
When setting up your Wyze Video Doorbell, you hear "QR code incorrect" when the QR code scans.
Troubleshooting
  2. Make sure your phone/tablet being used for setup is connected to a 2.4 GHz Wi-Fi network.
  3. Verify that you are scanning correct QR code.
    • Note: The QR code will display on your phone screen during the setup process. It is not located on the camera or its packaging.
  4. Ensure sure you’ve removed the plastic film from the lens of the camera.
  5. Confirm that nothing is obstructing the QR code on the screen (cracked screen or dirt).
  6. Make sure that the QR code is displayed in full. Scroll up/down on your mobile device if necessary.
  7. Make sure there is no glare on the screen while you are attempting to scan the QR code.
  8. Gently clean the lens of the camera using a microfiber or soft cloth.
  9. Hold your phone's screen steady in front of your doorbell, then move or adjust the distance slowly. Hold still at the new distance for 5 seconds to give your doorbell time to focus at the new distance.
  10. Try holding the QR code upside down for the doorbell to scan.
  11. Reset your doorbell and try again.
    1. With the doorbell connected to power, single-press the Reset button on the back of the device. No need to press and hold.
  12. If possible, try using a different device to scan the QR code.
Note: QR codes are only valid for 5 minutes after being generated. If the code is not scanned within that timeframe, a new QR code must be generated.
