Poor Image Quality
Problem
The live stream for your Wyze Video Doorbell is discolored, there is a purple or pink tint to the picture, there are lines in the image, or you are otherwise experiencing poor image quality.
Troubleshooting
  2. Check that your Wyze Video Doorbell’s firmware is up to date.
    2. If there is an update available for the doorbell, please move forward with updating it.
  3. Ensure there is nothing impairing the camera lens.
    1. Remove any plastic film/cover on the lens.
    2. Gently wipe the lens with a soft cloth to remove any dust or debris.
    3. If there is a third-party cover on the device, please remove it.
  4. Cycle through Night Vision Mode.
    1. Navigate to the doorbell’s live stream, then tap the 3 dots in the bottom right corner.
    2. Tap the moon icon, then cycle through Auto, On, and Off.
    3. Tap Close.
  5. Restart Wyze Video Doorbell.
    1. Restart the device by going to the doorbell’s settings > Restart Device > tap Restart.
  6. Power cycle Wyze Video Doorbell.
    1. Flip the breaker switch that is powering the doorbell to the off position, wait 10 full seconds, then flip the breaker switch back to the on position.
  7. Factory reset Wyze Video Doorbell.
    1. Press in on the doorbell while also pushing it up to remove it from the backplate. This exposes the back wiring and setup button.
    2. Press and hold the setup button until the status light turns solid yellow.
    3. Once the light turns solid yellow, release the setup button and wait for the light to begin flashing again.
    4. From there, set the doorbell up again as if it were a new device.
