Room mapping. Path planning. Efficient cleaning.
An all-new Wyze product for better home comfort, Wyze Robot Vacuum is loaded with tech, going way beyond cleaning to bring you a truly smart vacuum.
Some Wyze Robot Vacuum features we love:
- High-Precision Mapping. Wyze Robot Vacuum scans 2,016 distance points to navigate its environment.
- Area Selection. Edit map data to specify areas like rooms and hallways for targeted cleaning.
- Virtual Walls. Use the Wyze app to create Virtual Walls where the Wyze Robot Vacuum will not clean.
- Scheduled Cleanings. By time of day or days of the week, schedule when you want to clean.
- Cleaning Records. Observe and share the start time, duration, and cleaning area of your cleanings.
- Simultaneous Location and Mapping (SLAM). As the device scans its surroundings, SLAM technology allows the Wyze Robot Vacuum to track its location and optimize cleaning routes.
- Suction Options. Strong, Standard, and Quiet options let you control suction power, noise level, or a balance of the two.
