To set up Wyze Robot Vacuum:
- On your mobile device, turn your cellular data OFF.
- Some devices may try to automatically connect to cellular data while not connected to Wi-Fi. This can prevent successful setup.
- In the Wyze app, tap Home, then tap the plus sign + on the top right.
- On the Add menu, tap Device.
- Tap Home > Wyze Robot Vacuum.
- Press and hold the Home and Power buttons on the vacuum. It will say “Wi-Fi connection has been reset.” Tap Next in the app, and follow the onscreen instructions to connect to Wi-Fi.
- Once connected, you’ll be prompted to name the device.
- You're all set! Now you can use the app to start a Clean.
