Wyze Robot Vacuum Tech Specs
Wyze Robot Vacuum Device Details
Color: Black
Robot Vacuum Dimensions
Length: 13.8 in
Width: 13.8 in
Depth: 3.7 in
Charging Station Dimensions:
Length: 6.06 in
Width: 2.95 in
Depth: 3.9 in
Robot Vacuum Weight
7.2 lbs
Hardware Highlights
  • HEPA filter
  • 550ml dustbin
  • NIDEC brushless motor
Battery
  • 3200 mAh lithium-ion battery
Phone Compatibility
  • Android 7.0+
  • iOS 14.0+
Power Specs
Vacuum
Rated Voltage: 14.8
Rated Power: 33W
Battery Capacity: 3200mAh
Charging Station
Rated Power: 24W
Rated Input: 20V⎓1.2A
Rated Output: 20V⎓1.2A
Rated Frequency: 50/60Hz
Processing Power
A4 Cortex-A7 processor
Mali400 GPU
Suction Power
2100 Pascal
Sensors
Laser Distance sensor (LIDAR)
Induction sensor
Cliff and drop sensor
Accelerometer sensor
Gyroscope sensor
Collision sensor
Recharging sensor
LED Indicator
Top. Blue + Yellow
Connectivity
2.4GHz Wi-Fi
Operating Temperature
32°F - 130°F (-0°C - 55°C)
Weather Resistance
Indoor use only
Certifications
TBD
Languages
English
Warranty
1-Year
