LIDAR sensor
Your built-in collision insurance.
The LIDAR sensor is a spinning laser on top of the vacuum. Every second, it spins around 6 times and measures the distance to 2,016 different points in the room to build a map. You can see, edit, and save the map in the Wyze app.
