Wyze Robot Vacuum won't charge.
Check the charging station and vacuum.
If your Wyze Robot Vacuum won't charge, make sure that there is enough space for the vacuum to reach the charging station and rotate itself to charge.
Then check the electrodes. Make sure they're wiped clean of any dust or dirt that may be interfering with the charge, then try charging again.
