My vacuum doesn't clean every room, skips areas.
Problem
Wyze Robot Vacuum does not clean every area during a run, and skips one or more rooms.
Possible Causes:
  • The vacuum was manually moved during the first mapping / cleaning.
  • Wyze Robot Vacuum was unable to complete the first clean on its first battery charge, which can cause issues during the next session.
  • There were obstacles blocking off an area / room during the first mapping / cleaning.
Troubleshooting Tips:
  • Do not interrupt or move the vacuum during a clean.
  • Make sure paths to each room in an area are clear of obstacles.
  • Reset the map, then start a "Clean" with the vacuum starting at the charging station and returning to the charging station with no interruptions during the clean.
