I see a binding error when trying to set up my Wyze Robot Vacuum.
Presents as: You see a binding error when trying to set up your Wyze Robot Vacuum.
Troubleshooting:
  1. If you are using an Android device:
    1. Make sure your Wyze app is updated to version 2.16+.
    2. In the Wyze app, navigate to the Account tab > About.
    3. The version is listed under the Wyze logo.
  2. If you are using an iOS device:
    1. Make sure your  Wyze app is updated to 2.16.48+.
    2. If using iOS 14 or later, ensure that Precise Location is ON.
      • Setting > Privacy > Location Services > Precise Location.
  3. Force Close your Wyze app.
  4. Factory reset your Wyze Robot Vacuum.
    1. Press and hold the home button for 5 seconds.
    2. You will hear “factory reset will begin.”
    3. Release and hold the home button again for 5 seconds.
    4. You will hear “Factory reset was successful.”
    5. Try the setup again.
