My robot vacuum is making weird noises
The brushes or wheels may be clogged.
If your Wyze Robot Vacuum is making weird noises while cleaning, the main brush, edge brush and/or the wheels may be clogged with foreign objects.
Turn off your vacuum, turn it over, and manually clear the brushes and wheels.
Tip: Wyze Robot Vacuum comes with a cleaning tool at the base of the vacuum.
