Suction Options
How clean do you want your floors?
In the Wyze app, you can select how strong you want the vacuum's suction to be. This lets you choose between power, noise level, or a balance of the two.
Choose between Quiet Mode, Standard Mode, and Strong Mode.
The default cleaning setting is Standard Mode.
