A zone (or zones) aren't working
Problem
When using Wyze Sprinkler Controller, water does not start when you run a zone or multiple zones.
Note: Only 1 zone will run at a time. The sprinkler controller will run each zone individually until the full run cycle has been completed.
Troubleshooting Tips:
If a zone (or zones) aren't working, you likely have an issue with wiring.
  1. Make sure the wire going to the Wyze Sprinkler Controller is fully inserted and secure.
  2. Check that the C wire or wires from the solenoids are connected to the C terminal of Wyze Sprinkler.
  3. All wired and powered, but still not working? Please contact support for more help.
