How do I clean my Wyze Robot Vacuum dustbin?
The dustbin is the compartment that collects what your vacuum picks up. Unlike the vacuum's filter and brushes, the dustbin only needs to be emptied into the trash and reinstalled in the vacuum.
To clean your vacuum's dustbin:
  1. Lift the top cover on the vacuum.
  2. Pull to remove the dustbin from the vacuum.
  3. Empty its contents into a waste bin.
  4. Replace the dustbin, and close the vacuum cover.
