I can't install Wyze Thermostat on my own. What do I do?
Call your local HVAC technician for help.
We've designed Wyze Thermostat to be easy to install if your system is compatible. But if you're unsure, or don't feel prepared to wire and install your own thermostat, don't go it alone. Stop and call a professional.
Should I contact Wyze Support?
Our agents would love to help, but they may not be able to from afar. Wyze support agents are not able to give specific installation instructions for the thermostat, nor are they able to offer the hands-on assistance you can get from a local technician.
