How to factory reset your Wyze Bulb Color
Factory resetting your Wyze Bulb Color can be used to remove the current settings from your bulb. This can be used when you've changed your WiFi settings, or when you need to start fresh.
To factory reset your Wyze Bulb Color:
  1. Turn on/off the light switch associated with the bulb 3 times.
  2. Wait for your Wyze Bulb Color to start pulsing slowly.
  3. Once the bulb starts pulsing, you can either set it up again or turn the light off to preserve the factory state.
