The Dusk-to-Dawn feature isn't working.
Problem
Wyze Plug Outdoor isn't turning on and off according to your ambient brightness settings (Wyze Plug Outdoor > Plug Settings > Brightness). It doesn't turn off when it's light out, or turn on when it's dark.
Troubleshooting Tip:
The Dawn-to-Dusk feature is powered by a built-in light sensor on the front of the outdoor plug. Please make sure that the front surface of the outdoor plug is pointed outward and isn't in shadow, so that the light sensor turns the plug on and off .
