Wyze Plug Outdoor isn't responding to voice commands.
Problem
Wyze Plug Outdoor doesn't respond to voice assistant commands, like Alexa and Google Assistant.
Troubleshooting Tips:
  • Make sure the plug is connected to power, and the sockets are on.
    • Is the status light lit up?
  • Make sure the plug is connected to the Internet.
  • Make sure that your Alexa/Google Assistant account is linked to your Wyze account. An easy way to check is if you can command other Wyze devices you own.
