My Wyze Plug Outdoor turns on and off by itself.
Problem
Your Wyze Plug Outdoor turns on and off unexpectedly, without you turning it on yourself.
Troubleshooting
  2. If possible, check that your Wyze Plug Outdoor’s firmware is up to date.
    2. If there is an update available for the plug, please move forward with updating it.
    3. Note: You must be connected to BluetoothⓇ for the firmware to update.
  3. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  4. Check that no shared users are turning the plug off/on.
  5. Power cycle the plug.
    1. Remove the plug from its power source then plug it back in.
  6. Factory reset the plug and set it up as a new device.
    1. To factory reset, press and hold one of the power buttons for 10 seconds.
