How do I factory reset Wyze Floor Lamp?
To factory reset Wyze Floor Lamp:
  1. Toggle the power switch on the cord 5 times.
  2. The light will pulse briefly when the lamp is successfully reset.
To factory reset the BluetoothⓇ remote:
  1. On the back of the remote, open the battery cover.
  2. With the battery still installed, press and hold the reset button for at least 3 seconds.
  3. The status LED will flash, then steady when it has been successfully reset.
