Wyze Window Cam Mounting Troubleshooting
Problem
Your Wyze Window Cam won’t adhere to the hook-and-loop mount or keeps falling off of the mount.
Troubleshooting
  1. Check if the mounting sticker is securely attached to the window.
    1. If not, remove the current mounting sticker, clean the designated installation area, and install the backup mounting sticker.
    2. Note: The included mounting stickers are considered one-time use. Ensure it is positioned in the final location before installing it.
  2. The hook-and-loop mount may lose its effectiveness due to trapped dirt or lint. Clean the fibers on both the mounting sticker and the front of the camera with a stiff brush, tweezers, or a fine-tooth comb.
  3. Check the surface of the mounting sticker to check if the hooks are significantly worn.
    1. If so, remove the current mounting sticker, clean the designated installation area, and install the backup mounting sticker.
  4. Make sure that the camera’s power cable is hanging naturally and is not pulled tight or in a way that would impact its secure placement on the mounting sticker.
