Poor Audio Quality
Presents as:
Static or distorted audio when trying to use the Wyze buds pro.
Troubleshooting:
  1. Confirm the Wyze app is up to date.
  2. Confirm the Wyze Buds Pro Firmware is up to date.
  3. Make sure the phone/device's Bluetooth is turned on.
    • Try disconnecting the Bluetooth, and reconnecting.
  4. Move closer to the Bluetooth device.
  5. Make sure the Buds Pro is charged.
    • Wired Charging: recommended charge time is at least 2 hours.
    • Charging times using a wireless charging pad will differ depending on the pad used, but the charge time should not vary too much.
  6. Try a factory reset, and set the Wyze Buds Pro back up in the app.
    • With the Buds in the case, Press and Hold the button for 20 seconds.
  7. Submit a log:
    • In the Wyze app, tap Account > Wyze Support > Submit a log
    • Select the product family.
    • Fill the form accordingly.
    • Confirm send log files is checked off
    • Tap submit
