No power
Presents as:: My Buds Pro will not power on
Troubleshooting:
  1. Make sure the Buds Pro is charged.
    • Wired Charging: recommended charge time is at least 2 hours.
    • Charging times using a wireless charging pad will differ depending on the pad used, but the charge time should not vary too much.
    • Try a 15-minute quick charge, then reconnect to Bluetooth and try again.
  2. Try a factory reset, and set them back up in the Wyze app.
    • With the Buds in the case, Press and Hold the button for 20 seconds.
