Wyze Buds Pro Connectivity Troubleshooting
Problem
Your Wyze Buds Pro show offline in the Wyze app, have trouble connecting, or disconnect frequently.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Make sure the earbuds are fully charged.
    1. We recommend charging them inside their case for at least 2 hours.
    2. Once fully charged, the status light on the case will be solid green.
  3. Check the Bluetooth® connection.
    1. In your phone’s settings, toggle Bluetooth® off and then back on.
    2. Ensure your earbuds are within the Bluetooth® range of your phone.
      • This distance varies by device but is generally about 30 feet.
    3. If the earbuds were previously connected, forget the device in the Bluetooth® settings and then pair it again.
      • Note: If your Wyze Buds Pro were previously connected to other phones/tablets, you’ll need to unpair them from those devices as well.
    4. If there are other devices connected to your phone via Bluetooth® or other apps currently using Bluetooth® that may be causing interference, unpair the devices or close the apps.
  4. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  5. If possible, check that your Wyze Buds Pro firmware is up to date.
    2. If there is an update available for the earbuds, please move forward with updating them.
  6. Force close the Wyze app.
  7. Restart your phone.
  8. Factory reset Wyze Buds Pro.
    1. Place your Wyze Buds Pro into the charging case.
    2. Press and hold the pairing button on the side of the case for 20 seconds.
    3. Walk through setting up your earbuds like new in the Wyze app.
  9. Try a different phone/tablet, if possible.
