Poor Audio quality(Zoom/Apps)
Presents as::
Poor voice quality. Static, distorted sound during zoom calls and/or using apps
Troubleshooting
  • This is a known bug with Zoom that occurs on many brands of earbuds and headphones, including Wyze earbuds and headphones.
  • If you experience issues while using other apps:
    • Please use Os version Windows 10+ or Mac OS X+
    • Make sure the computers Bluetooth setting is connected to the headphones
    • Make sure you have chosen the headphones as the output microphone instead of the computer's built-in microphone.
  • Submit a log:
    • In the Wyze app, tap Account > Wyze Support > Submit a log
    • Select the product family.
    • Have the customer fill out the form accordingly.
    • Confirm send log files is checked off
    • Tap submit
