My Wyze Buds have poor audio quality during calls.
Problem:
There is static or distorted audio during phone calls when using Wyze Buds.
Troubleshooting:
  1. Make sure your Wyze app is up to date.
  2. Make sure your Wyze Buds firmware is up to date.
  3. Check that BluetoothⓇ is turned on on your phone.
    • Turn off Bluetooth, then turn it back on.
  4. Make sure your Wyze Buds are close to your Bluetooth-enabled phone.
  5. Submit a log to our engineers:
    • In the Wyze app, tap on your Wyze Buds > Settings > Wyze Support > Submit a log.
  6. Factory reset your Wyze Buds, then set them up again in the Wyze app.
    • With the buds in the case, press and hold the reset button for 20 seconds.
