Problem
Your Wyze Buds show offline in the Wyze app, have trouble connecting, or disconnect frequently.
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- Make sure the earbuds are fully charged.
- We recommend charging them inside their case for at least 2 hours.
- Once fully charged, the status light on the case will be solid white.
- Check the Bluetooth® connection.
- In your phone’s settings, toggle Bluetooth® off and then back on.
- Ensure your earbuds are within the Bluetooth® range of your phone.
- This distance varies by device but is generally about 30 feet.
- If the earbuds were previously connected, forget the device in the Bluetooth® settings and then pair it again.
- Note: If your Wyze Buds were previously connected to other phones/tablets, you’ll need to unpair them from those devices as well.
- If there are other devices connected to your phone via Bluetooth® or other apps currently using Bluetooth® that may be causing interference, unpair the devices or close the apps.
- Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
- Make sure that it is set to Always or While Using the App.
- For iOS users, make sure that Precise Location is turned on.
- If possible, check that your Wyze Buds firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the earbuds, please move forward with updating them.
- Force close the Wyze app.
- Restart your phone.
- Factory reset Wyze Buds.
- Place your Wyze Buds into the charging case.
- Press and hold the pairing button on the back of the case for 20 seconds.
- Walk through setting up your earbuds like new in the Wyze app.
- Try a different phone/tablet, if possible.
