My Wyze Scale BodyScan’s battery level is incorrect.
Problem
The battery life on my Wyze Scale BodyScan seems lower or higher than it should be.
Troubleshooting
    1. In your Wyze app, navigate to the Account tab > tap About.
    2. Your current app version will be listed beneath the Wyze logo.
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
  2. If possible, check that your Wyze Scale BodyScan’s firmware is up to date.
    1. You can check this by going to the Account tab > Firmware Update.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Force close the Wyze app, then reopen it.
  4. Make sure the batteries being used are four 1.5V AAA batteries.
  5. Power cycle Wyze Scale BodyScan.
    1. Remove the batteries for 10 seconds, then reinstall them.
  6. Factory reset Wyze Scale BodyScan.
    1. On the back of the scale in the battery compartment, find the UNIT button.
    2. Press and hold it for 5 seconds until the LED display shows "Clr".
    3. Set up the scale as new.
