Problem
When you try to update the firmware for your Wyze Scale BodyScan, it fails.
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- Verify that the scale is connected to the Wyze app.
- In the Wyze app, select Wyze Scale BodyScan, then step on the scale to activate it.
- Ensure that "Connected" displays in the app and the Bluetooth® symbol appears in the upper-left corner of the scale's screen.
- Note: Wyze Scale BodyScan connects via Bluetooth® and must be connected to Bluetooth® to update the firmware.
- Keep the scale and mobile device close together, and keep the Wyze app open, for the entire update.
- Keep the scale awake during the update. It powers off after about 15 seconds of inactivity; step on or tap the scale to keep it active.
- Force close the Wyze app, then re-open it and try the update again.
- Power cycle Wyze Scale BodyScan.
- Remove the batteries for 10 seconds, then reinstall them.
- Factory reset Wyze Scale BodyScan.
- On the back of the scale in the battery compartment, find the UNIT button.
- Press and hold it for 5 seconds until the LED display shows "Clr".
- Set up the scale as new.
