My Wyze Scale BodyScan data is not auto-syncing with the Wyze app.
Problem
Body composition measurements are not automatically syncing to the Wyze app while it is closed, or are not syncing to the correct profile.
Note: Wyze Scale BodyScan is a Bluetooth® scale, so it does not sync in the background while the Wyze app is closed. Measurements taken while the app is closed are stored on the scale and will sync the next time that you open the Wyze app while Bluetooth® is connected.
Troubleshooting
    1. In your Wyze app, navigate to the Account tab > tap About.
    2. Your current app version will be listed beneath the Wyze logo.
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale BodyScan’s firmware is up to date.
    1. You can check this by going to the Account tab > Firmware Update.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Force close the Wyze app, then re-open it.
  4. Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
    1. Unpair any unused Bluetooth® devices from the phone/tablet.
    2. Toggle Bluetooth® off/on.
  5. Verify that the scale is syncing with the Wyze app.
    1. In the Wyze app, select Wyze Scale BodyScan, then step on the scale to activate it.
    2. Ensure that “Connected” displays in the app and the Bluetooth® symbol appears in the upper-left corner of the scale’s screen.
  6. Check that there is no unclaimed data in the app.
    1. In the Wyze app, select Wyze Scale BodyScan.
    2. If there is unclaimed data, there will be a “You have unclaimed data.” message at the top of the screen.
    3. If so, tap the message to assign the unclaimed data to the correct user, and tap Claim once done.
  7. Ensure the correct user profile is selected in the Wyze app while measuring.
  8. Power cycle Wyze Scale BodyScan.
    1. Remove the batteries for 10 seconds, then reinstall them.
  9. Factory reset Wyze Scale BodyScan.
    1. On the back of the scale in the battery compartment, find the UNIT button.
    2. Press and hold it for 5 seconds until the scale’s display shows "Clr".
    3. Set up the scale as new.
