My Wyze Scale BodyScan is not syncing with the Wyze app.
Problem
Wyze Scale BodyScan shows your weight on the screen, but the Bluetooth® symbol and other measurements are not displayed in the Wyze app.
Troubleshooting
    1. In your Wyze app, navigate to the Account tab > tap About.
    2. Your current app version will be listed beneath the Wyze logo.
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that your Wyze Scale BodyScan’s firmware is up to date.
    1. You can check this by going to the Account tab > Firmware Update.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Ensure the scale is not currently connected to another device.
    1. Wyze Scale BodyScan can only be paired with one device at a time.
  4. Force close the Wyze app, then re-open it.
  5. Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
    1. Unpair any unused Bluetooth® devices from the phone/tablet.
    2. Toggle Bluetooth® off/on.
  6. Turn off the mobile device, then turn it back on.
  7. Verify that the scale is syncing with the Wyze app.
    1. In the Wyze app, select Wyze Scale BodyScan, then step on the scale to activate it.
    2. Ensure that “Connected” displays in the app and that the Bluetooth® symbol appears in the upper-left corner of the scale’s screen.
  8. Check that there is no unclaimed data in the app.
    1. In the Wyze app, select Wyze Scale BodyScan.
    2. If there is unclaimed data, there will be a “You have unclaimed data.” message at the top of the screen.
    3. If so, tap the message to assign the unclaimed data to the correct user, and tap Claim once done.
  9. Power cycle Wyze Scale BodyScan.
    1. Remove the batteries for 10 seconds, then reinstall them.
  10. Factory reset Wyze Scale BodyScan.
    1. On the back of the scale in the battery compartment, find the UNIT button.
    2. Press and hold it for 5 seconds until the LED display shows "Clr".
    3. Set up the scale as new.
