Problem
The scale isn’t showing the correct weight.
Note: There is a range of acceptable measurement differences. The scale tolerance of Wyze Scale BodyScan is:
- 11-132lb: ± 0.66lb
- 132-265lb: ± 0.88lb
- 265-400lb: ± 1.1lb
Troubleshooting
- Confirm that your Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that your Wyze Scale BodyScan’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the scale, please move forward with updating it.
- Ensure that measuring is done correctly.
- The scale should be placed on a hard, flat surface.
- Feet must be barefoot.
- Excessively dry or damp feet may result in incorrect or no measurements.
- Knees should not be touching.
- Grip the handle with all fingers, with thumbs placed on the sensor area.
- Keep arms at a 30°– 45° angle while holding the handle.
- Remain on the scale until measuring is complete.
- Calibrate the scale.
- Step on Wyze Scale BodyScan to activate it.
- Step off the scale, and let it return to 0.0 lb.
- Verify that the scale is syncing with the Wyze app.
- In the Wyze app, select Wyze Scale BodyScan, then step on the scale to activate it.
- Ensure that “Connected” displays in the app and that the Bluetooth® symbol appears in the upper-left corner of the scale’s screen.
- Clean the scale’s surface.
- Wipe off the scale’s surface with a damp cloth, then try again.
- Power cycle Wyze Scale BodyScan.
- Remove the batteries for 10 seconds, then reinstall them.
- Factory reset Wyze Scale BodyScan.
- On the back of the scale in the battery compartment, find the UNIT button.
- Press and hold it for 5 seconds until the LED display shows "Clr".
- Set up the scale as new.
