Wyze Bulb Cam Pan Color Connectivity Troubleshooting
Problem
Your Wyze Bulb Cam Pan Color shows offline in the Wyze app, loads slowly, or disconnects frequently.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Bulb Cam Pan Color’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Confirm whether the status light is on.
    1. If not, refer to My Wyze Bulb Cam Pan Color will not turn on.
  4. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  5. Confirm that the camera is connected to a 2.4 or 5 GHz Wi-Fi network and that the network is functioning normally.
  6. Ensure the camera is securely inserted into the socket.
  7. Verify that the fixture the camera is installed in is physically powered on.
  8. Check if the camera is in a socket with a dimmer switch.
    • If it is in a socket with a dimmer switch, move the camera to a different socket, as dimmer switches are not recommended.
    • If it is in a dimmer switch and cannot be moved to a different socket, ensure that the dimmer switch is turned up to its highest setting.
  9. Ensure that Wyze Bulb Cam Pan Color has a good signal strength.
    1. You can check this in the Wyze app by going to the camera’s settings > Device Info > Signal Strength.
    2. If it has less than 2 bars, try moving the router and camera closer together.
  10. Try moving the camera to a different socket, closer to the router.
  11. Reboot the router.
  12. Power cycle the camera
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  13. Factory reset Wyze Bulb Cam Pan Color.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera like new.
