My Wyze Mesh Router is warm to the touch.
Problem
Your Wyze Mesh Router is warm to the touch.
Tips
Wyze Mesh Router is designed with heatsink technology that dissipates heat towards the bottom of the router chassis. The warmness of the bottom chassis is normal. The standard operating temperature for this device is between 120°F - 140°F (48.89°C - 60°C).
Here are a few tips for the proper placement of Wyze Mesh Router:
  1. Avoid placing Wyze Mesh Router in an enclosed space. The router should be placed in an open area and on a flat surface.
  2. Avoid covering Wyze Mesh Router with any objects.
  3. Do not place Wyze Mesh Router on top of or next to any hot surfaces or large electronic devices such as a TV, stove, kitchen appliances, etc.
  4. Avoid direct sunlight.
  5. Avoid placing the router on soft or cloth surfaces as this will prevent heat from dispersing from the bottom of the device.
