My Wyze Mesh Router’s backhaul is incorrect.
Problem
The backhaul for your Wyze Mesh Router or Wyze Mesh Router Pro is only showing as wireless even though it is wired or is showing incorrectly.
Troubleshooting
  1. Confirm your Wyze app is up to date.
    3. Compare your app version to the latest app version listed here on our Release Notes & Firmware page.
  2. Check that your Wyze Mesh Router’s firmware is up to date.
    2. If there is an update available for the router, please move forward with updating it.
  3. Power cycle the impacted Wyze Mesh Router.
    • Unplug the device for 30 seconds to 1 minute, then plug it back in.
  4. Check the backhaul type.
    1. In the Wyze app, select the impacted satellite Wyze Mesh Router.
      • Note: This option is only available on satellite routers, not the primary root router.
    2. Under Connection, find the Backhaul option.
      • If the Backhaul option says Wired, the backhaul is wired.
      • If the Backhaul option says Wireless and has an RSSI value, the backhaul is wireless.
If the Backhaul option says Wireless but does not have an RSSI value, the backhaul is actually wired. If this is the case, don’t worry! Our team is aware of the issue and is working on a fix. Keep an eye out for updates here.
