My Wyze Cam Floodlight has poor audio quality.
Problem
You hear poor audio quality when speaking through your Wyze Cam Floodlight or in recorded events. Your Wyze Cam Floodlight has low or distorted audio.
Troubleshooting
    1. In your  Wyze app, navigate to the Account tab > tap About.
  2. Ensure that both your Wyze Cam v3 and Wyze Cam Floodlight’s firmware are up to date.
    2. If there is an update available for the devices, please move forward with updating them.
  3. If you experience poor audio quality when viewing the live stream or in recorded events, please try the following:
    1. Verify that audio is enabled in the camera’s live stream.
      1. Tap the speaker icon to enable sound.
      2. Navigate to Wyze Cam v3’s live stream.
    2. Ensure Record Sound is enabled.
      1. Toggle on Record Sound.
      2. In the Wyze app, go to the camera’s settings > Advanced Settings.
    3. Force close the Wyze app.
    4. Increase the volume on your phone/tablet.
    5. Test the audio on a different phone/tablet if possible.
  4. Power cycle the floodlight and camera.
    1. Start by flipping the breaker to the off position.
    2. Wait 5-10 seconds, and then turn the breaker back to the on position.
  5. Delete your Wyze Cam Floodlight from the Wyze app.
    1. From the Home tab of the Wyze app, tap Devices.
    2. Tap on your device in the list.
    3. Go to the floodlight's settings > Delete Device.
  6. Factory reset your Wyze Cam v3.
    1. Remove any microSD card inserted into the camera.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera and floodlight as new.
