The lights on my Wyze Cam Floodlight won't turn off.
Problem
Your Wyze Cam Floofdlight's lights do not turn off.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
  2. Confirm that Wyze Cam Floodlight’s firmware is up to date.
    2. If there is an update available for the floodlight, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  4. From the floodlight’s live stream, tap the floodlight icon to turn it off.
  5. Verify that the Floodlight Settings are set correctly.
    1. Navigate to the floodlight’s settings > Accessories > Floodlight Settings.
    2. Ensure that Floodlight Control is set to Auto.
  6. Verify that the Detection Settings are set correctly.
    1. Navigate to the Floodlight Settings > Detection Settings.
    2. Under Motion Detection Sensitivity, adjust the slider to Low.
    3. Under Sound Detection Sensitivity, adjust the slider to Low.
  7. Ensure that Wyze Cam Floodlight has a good signal strength.
    1. You can check this in the Wyze app by going to the floodlight’s settings > Device Info > Signal Strength.
    2. If it has less than 2 bars, try moving the router closer to the floodlight.
  8. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  9. Restart Wyze Cam Floodlight.
    1. Navigate to the floodlight’s settings > Restart Camera > Restart.
  10. Power cycle Wyze Cam Floodlight.
    1. Switch the breaker to the off position.
    2. Wait 5-10 seconds.
    3. Switch the breaker back to the on position.
  11. Factory reset Wyze Cam Floodlight.
    1. Remove any microSD card inserted into the floodlight.
    2. With the floodlight powered on, press and hold the setup button on the side of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the floodlight like new.
