Only one light on my Wyze Cam Floodlight is turning on.
Problem
When you turn on your Wyze Cam Floodlight, only one light turns on.
Troubleshooting
  2. Check that both your Wyze Cam v3 and Wyze Cam Floodlight’s firmware are up to date.
    2. If there is an update available for the devices, please move forward with updating them.
  3. Ensure all wiring is secure, including the wire connecting Wyze Cam v3 to your Wyze Cam Floodlight.
    • Make sure that the floodlight was installed properly by following the steps in our Wyze Cam Floodlight Installation Guide.
      • If you are ever unsure when dealing with wiring, please feel free to reach out to a licensed electrician at your discretion.
  4. Power cycle the floodlight and camera.
    1. Start by flipping the breaker to the off position.
    2. Wait 5-10 seconds, and then turn the breaker back to the on position.
  5. Delete your Wyze Cam Floodlight from the Wyze app.
    1. From the Home tab of the Wyze app, tap Devices.
    2. Tap on your device in the list.
    3. Go to the floodlight's settings > Delete Device.
  6. Factory reset your Wyze Cam v3.
    1. Remove any microSD card inserted into the camera.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera and floodlight as new.
