My Wyze Cam Floodlight is not triggered by PIR.
Problem
The lights on your Wyze Cam Floodlight do not turn on when the PIR sensor detects motion.
Troubleshooting
  2. Check that both your Wyze Cam v3 and Wyze Cam Floodlight’s firmware are up to date.
    2. If there is an update available for the devices, please move forward with updating them.
  3. Ensure the detection settings are set correctly.
    1. In the Wyze app, go to your floodlight’s settings.
    2. Under Floodlight Control, tap Auto.
    3. Under Turn on when dark, select Motion is detected by PIR sensor.
    4. Tap PIR sensor settings, and adjust the detection distance by dragging the slider bar between Near and Far.
    5. Ensure all 3 detection areas are enabled.
      • They will be green when enabled.
    6. Under Sensitivity, select High.
  4. Power cycle the floodlight and camera.
    1. Start by flipping the breaker to the off position.
    2. Wait 5-10 seconds, and then turn the breaker back to the on position.
  5. Delete your Wyze Cam Floodlight from the Wyze app.
    1. From the Home tab of the Wyze app, tap Devices.
    2. Tap on your device in the list.
    3. Go to the floodlight's settings > Delete Device.
  6. Factory reset your Wyze Cam v3.
    1. Remove any microSD card inserted into the camera.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera and floodlight as new.
Notes:
  • For best results, these updated settings should be tested at night.
  • For best results, we recommend trying to trigger motion by walking from left to right across the camera’s view while testing.
