My floodlight isn’t turning on when the camera detects motion.
Problem
The lights on your Wyze Cam Floodlight are not turning on when the camera detects motion.
Troubleshooting
  2. Check that both your Wyze Cam v3 and Wyze Cam Floodlight’s firmware are up to date.
    2. If there is an update available for the devices, please move forward with updating them.
  3. Adjust the camera’s detection settings.
    1. In the Wyze app, go to the linked camera’s settings.
    2. Select Detection Settings then adjust the Motion Detection Sensitivity slider to 100.
    3. Tap Detection Zone then toggle it off while testing.
  4. Check the floodlight’s detection settings.
    1. In the Wyze app, go to your floodlight’s settings.
    2. Under Floodlight Control, tap Auto.
    3. Under Turn on when dark, select Motion is detected by camera.
  5. Power cycle the floodlight and camera.
    1. Start by flipping the breaker to the off position.
    2. Wait 5-10 seconds, and then turn the breaker back to the on position.
  6. Delete your Wyze Cam Floodlight from the Wyze app.
    1. In the Home tab of the Wyze app, tap the pencil icon in the upper right corner.
    2. Tap Edit Devices.
    3. Tap the red removal icon next to the floodlight then tap Delete
  7. Factory reset your Wyze Cam v3.
    1. Remove any microSD card inserted into the camera.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera and floodlight as new.
Still need help?
