The battery is stuck in my Wyze Scale S.
Problem
The battery is stuck in the battery compartment or cannot be removed from your Wyze Scale S.
Troubleshooting
  1. Try pushing the battery back into the battery compartment so that the compartment’s spring pushes the battery back out.
  2. Roll/spin the battery little by little and attempt to remove the battery.
    • Sometimes changing the angle of the battery in this way allows for easier removal.
