About Wyze Battery Cam Pro
The latest and greatest in our line of battery-powered outdoor cameras.
Features we love about Wyze Battery Cam Pro:
  • Wire-Free + No Hub - Place it anywhere, indoors or outdoors, with a hassle-free setup. No wires, no hubs. Only pro-grade protection precisely where you need it most.
  • 2.5K HDR + Color Night Vision - Crisp 2.5K video with high dynamic range captures clear and detailed footage with richer colors, day or night.
  • Radar + PIR Motion Detection - Radar and PIR technology work together to provide precise detection so you can feel confident in every alert you receive.
  • Powerful Spotlight + Siren - An extra layer of security, illuminating dark areas with the 150-lumen built-in spotlight and warning intruders with an 80 dB siren.
  • Removable Battery Packs - Stop taking down your camera. Easily swap battery packs and eliminate security downtime.
  • Works with Wyze Battery Charging Dock + Wyze Solar Panel - Charge up to two battery packs at once with our new charging dock or harness the power of the sun with our solar panel for convenient and ready-to-use power supplies (sold separately).
  • Dual-Band Wi-Fi Connectivity - Connecting is easier and faster than ever with dual-band Wi-Fi that supports both 2.4 and 5 GHz networks.
  • Enhanced Two-Way Audio - Talk (or yell) to anyone easily with a built-in microphone and speaker.
  • Instant BluetoothⓇ Setup - No more QR code scanning. Setup is quick and easy with BluetoothⓇ.
  • Easy Control and Automation - Supports Alexa, Google Assistant, IFTTT, and Wyze Automations.
