Wyze Battery Cam Pro Comparison Chart
How do Wyze Cam Outdoor v2 and Wyze Battery Cam Pro compare?
Wyze Cam
Outdoor v2
Wyze Battery
Cam Pro
Battery Life Up to 6 months (with about 10-20 Events/day) Up to 6 months (with about 10-20 Events/day)
Battery Type 19.24 Wh 2x internal 2600 mAH/7.4 V rechargeable batteries 22.94 Wh 1x internal 6200 mAH/3.7 V rechargeable batteries
Base Station Compatible/Required Yes No
Camera Resolution  1080P 2K HD
Compatible Accessories Wyze Solar Panel Wyze Battery Charging Dock, Wyze Removable Battery Pack, Wyze Universal Mount, Wyze Solar Panel*.           *Requires Wyze Solar Panel USB-C Adapter Cable
Wi-Fi Connectivity  2.4 GHz 2.4/5 GHz dual-band
Field-of-View 130° (Diagonal) 134° (Diagonal)
Frame Rate Day: 20 FPS Night 10 FPS Day: 15 FPS Night: 15FPS
Integrations Alexa, Google, IFTTT Alexa, Google, IFTTT
IR Lights 4x 850 nm 2x 850 nm
MicroSD Card Compatibility Up to 256 GB Up to 256 GB (Coming Soon)
Motion Detection PIR PIR + Radar
Color Night Vision Yes Yes
Setup QR Code  Bluetooth®
Siren 80 dB 80 dB
Spotlight No Yes, Built-in spotlight (150 lumens)
Supported Services Cam Plus, Cam Protect, Wyze Home Monitoring, Wyze Web View Cam Plus, Wyze Home Monitoring, Wyze Web View
