Wyze Battery Cam Pro Tech Specs
Device Details
  • Model: WYZECOP
  • Color: White
  • Finish: Matte
  • Dimensions: 2.5 in x 1.8 in x 3.5 in (63.5 mm x 45.7 mm x 88.9 mm)
  • Weight: 0.94 lbs (0.43kg)
  • Materials:
    • Body: PC Plastics
    • Lens: Optical Glass
Power
  • Charging Port: USB-C
  • Cable Type: USB-A to USB-C Cable
  • Cable Length: 0.5 m (1.64 ft)
  • Power Adapter Compatibility: 5V 2A (not included)
Video
  • Resolution: 2.5K HD
  • Field of View: 134° diagonal
  • Frame Rate:
    • Daytime: 15 FPS
    • Nighttime: 15 FPS
Night Vision
  • Color Night Vision
  • 2x 850 nm IR LEDs
Audio
  • Microphone: Built-in, digital
  • Siren: 80 dB
  • 2-way Audio, simultaneous
Alerts
  • Push notifications
Storage
  • Cloud Storage
    • Stored in the AWS Cloud
  • Local Storage
    • Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
    • Supports up to 256 GB microSD cards in exFAT format
Connectivity
  • 2.4 GHz and 5 GHz Wi-Fi
  • 802.11 a/n/g/b, 2.4 and 5 GHz
  • BluetoothⓇ Low Energy (BLE)
Integrations
  • Alexa, Google Assistant, IFTTT
Supported Wyze Services
  • Cam Plus
  • Wyze Web View
  • Wyze Home Monitoring
Phone Compatibility
  • Supports Android 7.0+ and iOS 14.0+ or later
Temperatures
  • Operating Temperature: -4°F - 122°F (-20°C - 50°C), Humidity <90%
  • Storage Temperature: -40°F - 122°F (-40°C - 50°C), Humidity <90%
Weather Resistance
  • Indoor and outdoor (IP65)
Certifications
  • FCC, IC
Language
  • English
Warranty
  • 1-Year
Wyze Removable Battery Pack
  • Model: WBAT1
  • Weight: 3.9 oz (110 g)
  • Dimensions: 2.9 in x 1.6 in x 0.9 in (75 mm x  40mm x 22 mm)
  • Color: White
  • Battery Capacity: 6200 mAh
  • Battery Type: Lithium-ion
  • Output Voltage: 3.7 V
  • Input Voltage: 5 V DC
  • Operating Temperature: -4°F to 122°F (-20°C to 50°C)
  • Charging Temperature: 32°F to 122°F (0°C to 50°C)
  • Full Charging Time: Approximately 9 hours at 77°F (25°C)
Wyze Battery Charging Dock
  • Model: WYZEDBCD
  • Weight: 2.75 oz (78 g)
  • Dimensions:
    • Charging Dock: 2.6 in x 2 in x 1 in (58 mm x  52 mm x 26 mm)
    • Power Adapter: 42 mm x 40 mm x 23 mm
  • Color: White
  • Operating Temperature: 50°F to 104°F (10°C to 40°C)
  • Power Adapter Input: AC100-240V, 50/60Hz
  • Power Adapter Output: DC5V 2A
  • USB Cable: USB-A to USB-C
  • Power Cable Length: 6 ft (1.8 m)
