Charging your Wyze Battery Cam Pro
You can charge your Wyze Removable Battery Pack a few ways.
You have options when it comes to charging your Wyze Battery Cam Pro:
Wyze Battery Cam Pro can be used normally while the battery is charging. While the camera is rated for outdoor use, the provided cable is not, so we recommend bringing your camera inside to charge or using Wyze Solar Panel.
If you’re charging the battery using the provided cable, it will take about 9 hours for a full charge. However, if you’re using Wyze Battery Charging Dock, it will take about 8 hours and 30 minutes.
With normal use, Wyze Battery Cam Pro’s battery should last up to 6 months before needing to be charged again. Alternatively, you can purchase additional batteries to swap them out as needed. Normal use is considered about 10-20 recorded Events per day.
Additional Notes:
  • Wyze Battery Charging Dock and Wyze Solar Panel are sold separately.
  • Only Wyze Battery Charging Dock includes a power adapter. If charging without the dock, you will need to use a 5V 2A power adapter.
  • On the battery, there will be one solid green status light while charging, and two lights once fully charged.
