How do I factory reset Wyze Battery Cam Pro?
To factory reset Wyze Battery Cam Pro:
  1. Remove any microSD card inserted into the camera.
  2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light turns solid yellow.
    • To access the setup button, you will need to open the camera's battery compartment.
  3. Once the status light starts flashing yellow and blue, set up the camera like new by following along in the app or our Wyze Battery Cam Pro Setup Guide.
Note: If you’re troubleshooting issues with your Wyze Battery Cam Pro, be sure to Submit a Log before performing a factory reset.
