My Wyze Cam Floodlight v2 has poor audio quality.
Problem
You hear poor audio quality when speaking through your Wyze Cam Floodlight v2 or in recorded events. Your Wyze Cam Floodlight v2 has low or distorted audio.
Troubleshooting
  1. Confirm your Wyze app is up to date.
  2. Check that your Wyze Cam Floodlight v2’s firmware is up to date.
    2. If there is an update available for the floodlight, please move forward with updating it.
  3. Ensure any protective film is removed from the camera and that there is nothing blocking the camera’s microphone or speakers.
  4. Verify that audio is enabled in the floodlight’s live stream.
    1. Navigate to the floodlight’s live stream.
    2. Tap the live stream then tap the speaker icon to enable sound.
  5. Ensure Record Sound is enabled.
    1. In the Wyze app, go to the floodlight’s settings > Advanced Settings.
    2. Toggle on Record Sound.
    3. When viewing recordings, ensure the video sound is not muted.
  6. Force close the Wyze app.
  7. Increase the volume on your phone/tablet.
  8. Test the audio on a different phone/tablet if possible.
  9. If you have a microSD card inserted into the camera, check the recordings on a computer to see if the audio in the microSD card recordings has the same issue.
  10. Power cycle Wyze Cam Floodlight v2.
    1. Switch the breaker to the off position.
    2. Wait 5-10 seconds.
    3. Switch the breaker back to the on position.
  11. Factory reset Wyze Cam Floodlight v2.
    1. Remove any microSD card inserted into the floodlight.
    2. With the floodlight powered on, press and hold the setup button on the side of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the floodlight like new.
