How do I factory reset Wyze Cam Floodlight v2?
To factory reset Wyze Cam Floodlight v2:
  1. Remove any microSD card inserted into the floodlight.
  2. With the floodlight powered on, press and hold the setup button on the side of the camera for 10 seconds until the status light on the front of the camera turns solid red.
  3. Once the status light starts flashing red, set up the floodlight like new.
Note: If you’re troubleshooting issues with your Wyze Cam Floodlight v2, be sure to Submit a Log before performing a factory reset or power cycle.
