My Wyze Cam Floodlight v2 does not flash when the siren sounds.
Problem
The lights on your Wyze Cam Floodlight v2 are not flashing when the siren sounds.
Troubleshooting
  1. Confirm your Wyze app is up to date.
  2. Check that your Wyze Cam Floodlight v2’s firmware is up to date.
    2. If there is an update available for the floodlight, please move forward with updating it.
  3. Ensure the Floodlight Settings are set correctly.
    1. Navigate to the floodlight's settings > Floodlight Settings.
    2. Under Other Settings, toggle on Flash Light With Siren.
      • Note: If you don’t want your floodlight to flash when the siren sounds, toggle off this setting.
