Only one light on my Wyze Cam Floodlight v2 is turning on.
Problem
When you turn on your Wyze Cam Floodlight v2, only one light turns on.
Troubleshooting
  1. Confirm your Wyze app is up to date.
  2. Check that your Wyze Cam Floodlight v2’s firmware is up to date.
    2. If there is an update available for the floodlight, please move forward with updating it.
  3. Power off the floodlight by switching the breaker to the off position.
  4. Check all wiring to make sure it is secure.
  5. Make sure that Wyze Cam Floodlight v2 was installed properly by following the steps in our Wyze Cam Floodlight v2 Installation Guide.
    • If you’re ever unsure when dealing with wiring, we recommend reaching out to a licensed electrician at your discretion.
  6. Power on the floodlight by switching the breaker back to the on position.
  7. From the floodlight’s live stream, tap the floodlight icon to turn it off/on.
  8. Try rotating the angle of the floodlight heads to see if they light up.
  9. Adjust the brightness.
    1. Navigate to the floodlight’s settings > Floodlight Settings.
    2. Under Brightness Level, adjust the slider bar to High.
  10. Restart the floodlight.
    1. Navigate to the floodlight’s settings > Restart Camera > Restart.
  11. Power cycle Wyze Cam Floodlight v2.
    1. Switch the breaker to the off position.
    2. Wait 5-10 seconds.
    3. Switch the breaker back to the on position.
  12. Factory reset Wyze Cam Floodlight v2.
    1. Remove any microSD card inserted into the floodlight.
    2. With the floodlight powered on, press and hold the setup button on the side of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the floodlight like new.
