My Wyze Cam Floodlight v2 is missing motion events or motion light triggers.
Problem
Wyze Cam Floodlight v2 is frequently missing motion events or motion light triggers.
Troubleshooting
  1. Confirm your Wyze app is up to date.
  2. Check that your Wyze Cam Floodlight v2’s firmware is up to date.
    2. If there is an update available for the floodlight, please move forward with updating it.
  3. Ensure the floodlight is set to record correctly.
    1. In the Wyze app, navigate to the floodlight’s settings > Event Recording.
    2. Enable Motion then select All Events.
    3. Tap Customize Detections.
    4. Next to Other Motion, ensure that the boxes are checked for both the Tag and Notify columns.
    5. Attempt to trigger the floodlight by creating movement in front of the device.
    6. Note: For Wyze Services users, once recordings for Other Motion are being generated, you can select the desired AI recordings by checking the other options in the Tag and Notify columns.
  4. Verify that the Detection Settings are set correctly.
    1. Navigate to the floodlight’s settings > Detection Settings.
    2. Under Motion Detection Sensitivity, adjust the slider bar to High.
    3. Tap Detection Zone and toggle it off while testing.
  5. Check that Notifications are set correctly.
    1. For the floodlight:
      1. Navigate to the floodlight’s settings > Notifications.
      2. Enable Notifications.
      3. Note: Tap Manage to be taken back to the screen to customize the Notify column for your recordings.
    2. For the Wyze app:
      1. Navigate to the Home tab of the Wyze app.
      2. Tap Account > Notifications > Push Notifications.
      3. Toggle on Push Notifications.
  6. Ensure the Floodlight Settings are set correctly.
    1. Navigate to the floodlight's settings > Floodlight Settings.
    2. Under Brightness Level, adjust the slider bar to High.
    3. Under Activate When, tap Motion.
      1. Confirm Motion is toggled on
      2. Select High Sensitivity while testing.
      3. Tap Lights Off Timer and set it to 5 mins while testing then tap Save.
      4. Tap Schedule and verify it is set to your preferred timeframe.
        1. Set a different schedule to clear any stuck settings then set it back to the preferred timeframe.
        2. Test the motion-activated lights during the set timeframe.
  7. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  8. Power cycle Wyze Cam Floodlight v2.
    1. Switch the breaker to the off position.
    2. Wait 5-10 seconds.
    3. Switch the breaker back to the on position.
  9. Factory reset Wyze Cam Floodlight v2.
    1. Remove any microSD card inserted into the floodlight.
    2. With the floodlight powered on, press and hold the setup button on the side of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the floodlight like new.
